What ram are you using? Where are you shopping / located?
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/1089712-cpu-cooler-under-50/#findComment-12774075
I'm in America and am using team force delta rgb and I am using newegg/amazon
https://linustechtips.com/topic/1089712-cpu-cooler-under-50/#findComment-12775111
Mugen 5 Rev. B: https://www.newegg.com/p/13C-0004-00075?Description=scythe cooler&cm_re=scythe_cooler-_-13C-0004-00075-_-Product
If you don't mind going through a bit more hassle to get an AM4 kit, the Ouranos is better: https://www.newegg.com/p/1DR-003S-00002
http://www.reeven.com/am4-upgrade-kit
https://linustechtips.com/topic/1089712-cpu-cooler-under-50/#findComment-12775173
1 minute ago, Adsome2007 said:
It's not good enough for overclocking
It's good enough for overclocking to the point where you wouldn't notice any performance difference between a D15 and it, temp normalized to 85C and noise normalized to bearable noise, soo
https://linustechtips.com/topic/1089712-cpu-cooler-under-50/#findComment-12775236
Yes bbn ymbut I would prefer for the CPU temp to be lower than 85 after I oc because I'm planning on keeping this build for a few years
https://linustechtips.com/topic/1089712-cpu-cooler-under-50/#findComment-12775239
OC discord recommends 85C or under for long term usage. I don't think there would be much benefit in keeping the max temps of the CPU under 85C vs at 85C for its lifetime.
https://linustechtips.com/topic/1089712-cpu-cooler-under-50/#findComment-12775241
and noisy. I'd say you need not to spend too much. Gammaxx400, Hyper212X or similar coolers would be way superior to stock Stealth. I'd even recommend Alpenföhn Brocken Eco Advanced, if available in your area.
Scythe Mugen5 is also very good, and cheap ~ 45 USD.
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1089712-cpu-cooler-under-50/#findComment-12775334
If you really care about looks, the 34 eSports is nice.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1089712-cpu-cooler-under-50/#findComment-12775548
