I would call bs.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/108869-usb-charging/#findComment-1455043
Long answer:
As it's using a better AC to DC converter as well as a better more stable transformer to giver you "Cleaner electricity" yes theoretically it is better. Now if it will actually make any kind of noticeable difference or not is really hard to tell. Honestly I doubt you'll really notice any difference. Most people who claim that it works magic are just lying. (It depends if you plan on using the same battery for a super long time or not, which by the time it makes a difference you'll probably want a better phone anyways.)
Short answer: Makes no real difference.
"Her tsundere ratio is 8:2. So don't think you could see her dere side so easily."
Planing to make you debut here on the forums? Read Me First!
unofficial LTT Anime Club Heaven Society
https://linustechtips.com/topic/108869-usb-charging/#findComment-1455048
Actually, it's not BS.
Most wall plugs operate at around 1-2 amps, which although charges the battery quickly, actually makes the battery wear out quickly. Quick charges and discharges drains not only the charge inside the battery, but also the amoount of charge it can hold.
Your computer will offer 0.5A charging, which will prolong the life of the battery as it is not charging as quickly. It may take 4 hours to charge instead of 1.5, but it is well worth it for the extra life you'll get out of the device.
Compatible with Windows 95
https://linustechtips.com/topic/108869-usb-charging/#findComment-1455132
