I am not sure if this should be in displays or graphics card forum, but I'll start here. I have searched the forum and google. There are similar issues that I am seeing but no clear solution.
I have a user that has two monitors, one on DVI-D the other on VGA, the one on DVI will randomly black out for a few seconds. This issue follows the DVI cable. I have tried two different DVI cables, and a display port to dvi adapter and still has this issue. I have tried both onboard graphics and a Geforce GT 710 and the issue persists.
I'm trying to get a hold of a display port to vga adapter to test that.  Baring that I'm going to try running on VGA from the Geforce and VGA from the on-board video and see if it works that way. (The monitors support both DVI and VGA, and they are both brand new, the computer is also brand new. not even 4 months old yet.)
I'm not sure if I'm really looking for help here or just needed to vent. either way thanks to any one who replys.
https://linustechtips.com/topic/1088308-display-blacks-out-randomly/
Try using the monitor with another pc to see if the problem follows it.
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
