3 minutes ago, easyfreezy82 said:
I just wanted to know if I can run a computer fully off of ssd drives or m.2 nvme drives. No hard drives
The computer doesn't care, but your hard drive will cry.
https://linustechtips.com/topic/1087352-need-help/#findComment-12755902
Yep, that's not a problem. I'm using a single 500GB SSD in my build right now.
"Make sense? Oh, what fun is there in making sense?"
-Discord
https://linustechtips.com/topic/1087352-need-help/#findComment-12755927
As long as your motherboard supports whatever option you pick (ie. Don't try to put an m.2 into an old MoBo that doesn't have a slot for it), your computer will just use it like any other drive. Most, if not all Ultra-portables laptops have been SSD or m.2 nvme only for the last few years. I think Apple have been using them since 2013 in their Macbooks. So, there are probably tens of millions of computers out there using only SSD or m.2 nvme.
Edited by Joluch
Clarification
CPU: Vulnerable to Meltdown | Motherboard: Has LEDs that I can't see | RAM: Bought too much | GPU: Mostly satisfactory so far in our relationship | Case: Shiny, black, very heavy and tall, with a Firefox sticker | Storage: Has too many old HDDs | PSU: Hasn't blown up yet like it's predecessor | Displays: Mismatched from Craigslist | Cooling: As many Noctuas as there are fan headers | Keyboard: Keys are fading |  Mouse: Needs cleaning |
https://linustechtips.com/topic/1087352-need-help/#findComment-12755949
As long as a storage device is present to hold the operating system, no problem. Hell, SSDs work as far back as SATA one days, long before they were even invented. They use the same protocols so they are seen as the same thing.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1087352-need-help/#findComment-12755964
