Temperature for 2080ti?
Solved by Mnky313,
1 minute ago, knn said:I have just build my very first computer and i can feel on my 2080ti that it has already startet to heat a little bit already when i am installing windows?
Just to be sure: How hot should they get when they are not really in use? The only thing running is windows install on a 4K monitor. It is not very hot or anything. I just want to make sure since its a kind of expensive card.
It should be fine, graphics cards get warm even when nothing is really happening unless the GPU is getting so hot it's unbearable to touch, modern GPUs have temperature fail safes built in to stop the GPU from damaging itself.
