I recently ordered a 4600MHZ RAM CL 18. In my country the best MOBO we have available is ASUS MAXIMUS XI HERO, which only supports till 4400Mhz of RAM. My initial intention is to run my RAM at 4266Mhz at tight timing, CL16. So, my question is will buying a MOBO with low rating for ram support fine with running at tight timing preferred or should i just order a better one like ASUS MAXIMUS XI APEX/GENE.
I want the tight timings with atleast 4000+Mhz.
https://linustechtips.com/topic/1084874-help-needed-regarding-ram-and-mobo/
Buy an Apex, the Hero can't hold an overclocked 9900k. the Gene doesn't support SLI so that rules it out. Even the Extreme is not extreme enough
Desktop benching:
5 minutes ago, teriyakikoon said:
How does HERO not support 5.0Ghz I9 9900K
It is the most overpriced yet underwhelming motherboard under Z390 chipset, you're basically only paying for the aesthetics and ROG branding with it.
The Aorus Master Z390 is a much better alternative for both the memory OC and the CPU.
You can watch a very educational video on the matter here:
Personal Desktop":
Luna, the temporary Desktop:
12 minutes ago, Queen Chrysallis said:
Got no MSI Godlike for sale there? Can't top that one if you're going for an overkill board
Yeah between the Apex and the Godlike I'd probably go Godlike too... but put an Aorus Waterforce Xtreme in the middle and things could change :P
Personal Desktop":
