Build for my parents
Final choices, and rational:
I chose AMD instead of Intel, completely based on price. The 8320 had a very nice sale, and was purchased for a hundred dollars less than the i5.
I went Micro ATX, because I didn't see a real compelling reason not to, and if I can make it smaller, I will.
1866 mhz ram, for the speed, and also because it didn't cost much extra.
350D because it's beautiful, and a cheaper case wouldn't have saved much, yet would have been more flimsy (normally).
I also chose the case, because it has a window. If you check out the parts list, you'll notice that everything is matching, (I worked hard on that
), nice and blue, and beautiful. My parents keep their computer in a common area, and I want it to be praised.
My reason for the 8320 also has to do with AutoCAD. After talking with my parents (mostly my mom), I found a bit of information that would have been nice from the start...
She doesn't do much on it! She does very basic things on it, once a month maybe... So It wasn't really something I should have prioritized for.
Either way, Thanks for all of the help guys, you helped me get a better system for my parents, and a better GPU for myself ![]()
