i was thinking of buying EK's phoenix kit since they're dirt cheap nowadays to replace my aging(and loud) dark rock pro 3
my question is:is the flowrate of 150L/h enough to support extra radiators and blocks in the future?
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1084343-how-much-flow-rate-is-enough/
Doesn't sound like enough to me.
I have a DDC rated 600 L/h running at 40%. Assuming a linear level that's 240 L/h which isn't even enough to pull any trapped air out of high points. I consider 40% enough for my uses but I do turn it up occasionally.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
Id rather spend more and have better performance. Flow goes a long way with multiple rads. But that also depends if you care about chasing that 3-5c difference it could yield.
1 GPM is enough. Beyond that you get diminishing returns.
1 GPM is about 227 LPH.
Minimum recommend would be 0.5 GPM, thats about 114 LPH.
So long as your between those two you fine.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
in my case, spending more means spending about double to get the equivalent rad
How so?
9 minutes ago, Mick Naughty said:
How so?
if going custom, I was planning on using a d5 pump/res combo,with a ce rad, some 30 euro fans, and some fittings and about 15 euros of tubing it comes out to about 380 euros
while the EK phoenix setup only requires a 50 euro block and 140 euro rad
Ok so that isn’t the context at all. You just said it would cost more for an equivalent rad.
If you dont mind turning the fans up to try and make up for the lack of flow then go the cheaper route. Simple answer, the flow isn’t good to begin with, but depends on the components and what you’re expecting to achieve.
