5 minutes ago, GGarcia411 said:
I'm new to building/upgrading PCs and I've been thinking about upgrading my CPU. I just don't know which ones I can upgrade to.
My motherboard is a GIGABYTE GA-AB350M-DS3H and my CPU is a Ryzen 3 2200G.
You should be able to go Ryzen 5 higher model.  It will help things, and just like badreg said what GPU you got ?  For monitor I bet he has a 60hz and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1083908-help-me-upgrade-my-cpu/#findComment-12731151
6 hours ago, Trevor87 said:
Just a suggestion also make sure all your voltage is correct on cpu and ram in the bois.
I dont if they fix that bug yet.
Ya good one AMD can get picky what not.
https://linustechtips.com/topic/1083908-help-me-upgrade-my-cpu/#findComment-12731666
Since I have a 2000, does the CPU I choose also have to be a 2000 series? For example a Ryzen 5 2600X?
https://linustechtips.com/topic/1083908-help-me-upgrade-my-cpu/#findComment-12731685
https://www.gigabyte.com/Motherboard/GA-AB350M-DS3H-rev-1x/support#support-cpu
Looks like your motherboard supports the new Ryzen CPU's as well, but it's VRM doesn't look very sturdy. I think Ryzen 5 3600 would be a reasonable upgrade, it only requires you to update your BIOS.
3700X | NH-D15 | X470-F | 2x16GB @3200MHz | RTX 2060 Ventus OC
RM650x | Fractal Design R4 | NVMe 970 EVO Plus 512GB | SATA 850 EVO 512GB
<Build Log>
https://linustechtips.com/topic/1083908-help-me-upgrade-my-cpu/#findComment-12731843
