Quiet Full ATX Case
Go to solution Solved by MikkoHalonen,
21 hours ago, TVwazhere said:
The Fractal Design Define R6 sounds like the case for you. Fits 6 3.5" drives natively (expandable to 11), sound dampening foam all around that's best suited for coil whine while having better airflow the Dark base Pro 900, and can fit up to 180mm tall CPU tower coolers. Available with or without USB 3.1 Gen 2 Type C as well
Seems like that would be a sweet case, if only it were a full tower. Based on the GN reviews, I'm more confident in the Dark Base 900 being able to cool both the GPU and the CPU under load. And it has slots for more fans if needed. It's a bit pricey, but it's not like you buy a new case every decade.
I'm looking for a quiet full tower case. Quiet because I'm annoyed by coil whine, not by fans. On the other hand, I'm also an overclocking gamer, so I'd want something that can handle such things by revving up the fans. Is such a thing possible, or will all 'quiet' cases diminish my ability to get the best OC out of my CPU and GPU with air? Will such cases be able to control the fans themselves based on temps or will I have to do it manually?
What are my alternatives, other than be Quiet!'s Dark Base 900? Requirements not already mentioned:
- Black or almost black with little flair and no window (at least on the left side)
- At least five 3.5" slots
- Room for a large tower cooler (I kinda assume all full towers will have room)
If the Dark Base 900 is my only option, which version should I get? The base version seems otherwise most suitable for me, but will I be missing the higher RPM fans in the Rev. 2?
https://linustechtips.com/topic/1083489-quiet-full-atx-case/
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12727910
Case porn...
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12727916
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12730247
I've got an overclocked 8700K to 5GHz on an AIO, 1080Ti overclocked to 2050Mhz.  I added another fan to complement the 3 already in there plus the AIO's 3.  7 fans and no thermal issues ever.  I hear a fan ramp up once in a while, you can't get away from that when OCing high.   If a fan has access to outside air to draw in, it has access to your ears thru those same vents.  Never heard a peep of coil whine ever tho.
When you need confidence when cooling under load, you're talking your own human brain issues.  The case cools fine, but if you need to get the feels that a full tower will do better, by all means buy the Dark Base 900.
Just don't think the R6 can't cool ANY GPU and CPU under load.  It does.  Well.  :)
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12730261
Just because it's not marked as a "Full Tower" doesnt mean anything about it's actual size, much less cooling capacity.
Take for example, the Silent base 801. Even though it's classified as a "mid tower", volume wise it's bigger than the Dark Base Pro 900!
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12730348
If I was getting an AIO, I would probably get the R6! But I'm worried about the expense, it breaking and the extra noise. Thought I realize the first and last point might be moot.
I actually checked the height (over 10 cm less).
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12730602
Volume, not height.
82L
83.7L
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12730685
The sound dampening foam in cases really doesn't do much at all (from the videos Ive watched on YT) - however I always recommend the CoolerMaster HAF series - I have an XM (they still sell the full tower) and its my most favorite, airflow filled, silent with huge OC PC I own.
I just recently purchased a Cougar MX330-X which is nice but not a full tower for you, and doesn't support the largest air coolers - I like it though because great airflow so my Ryzen Rig 1 in sig is silent now as well.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12730727
Fractal does sell a full tower with decent noise dampening, but it's slightly older.  The Define XL R2.
232 x 559 x 560 mm
https://www.fractal-design.com/home/product/cases/define-series/define-xl-r2-black-pearl
https://linustechtips.com/topic/1083489-quiet-full-atx-case/#findComment-12730769
