Hey guys so im upgrading my board/cpu/ram and i came across this possible issue in my pc part picker will it not work? thanks for any help!
"Some AMD X470 chipset motherboards may need a BIOS update prior to using Zen 2 CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions."
PCPartPicker Part List
Type Item Price
CPU AMD - Ryzen 5 3600 3.6 GHz 6-Core Processor $199.00 @ B&H
Motherboard Asus - Prime X470-Pro ATX AM4 Motherboard $154.88 @ OutletPC
Memory Corsair - Vengeance LPX 16 GB (1 x 16 GB) DDR4-3000 Memory $69.99 @ Newegg Business
Storage Samsung - 850 EVO-Series 250 GB 2.5" Solid State Drive Purchased For $0.00
Video Card EVGA - GeForce GTX 970 4 GB Superclocked ACX 2.0 Video Card (2-Way SLI) Purchased For $0.00
Case Rosewill - Challenger-U3 ATX Mid Tower Case Purchased For $0.00
Power Supply EVGA - SuperNOVA G2 750 W 80+ Gold Certified Fully Modular ATX Power Supply Purchased For $0.00
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $443.87
  Mail-in rebates -$20.00
  Total $423.87
  Generated by PCPartPicker 2019-07-17 01:40 EDT-0400
https://linustechtips.com/topic/1083298-possible-build-issue/
You need to find a x470 or b470 board with bios flash back or grab 1-2 second gen ryzen to flash newest bios.
Essentially almost all of MSI board have this feature or you can ask your retailer to do flash new bios as some retailers offer this service.
Magical Pineapples
https://linustechtips.com/topic/1083298-possible-build-issue/#findComment-12726471
would you know a good board that would not have this issue that does not blow the bank?
https://linustechtips.com/topic/1083298-possible-build-issue/#findComment-12726474
6 minutes ago, Cookiecrumbles222 said:
I'll recommend the following changes to be made...
CPU: AMD - Ryzen 5 3600 3.6 GHz 6-Core Processor  ($199.00 @ B&H)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.89 @ OutletPC)
Memory: OLOy - 16 GB (2 x 8 GB) DDR4-3200 Memory  ($63.99 @ Newegg)
Total: $377.88
Generated by PCPartPicker 2019-07-17 01:43 EDT-0400
Tomahawk is one of the best b450 boards out there which supports bios flashback (flashing bios without a CPU). I'd recommend dual channel ram. Also, I'll recommend you to skip sli, because newer games don't scale pretty well with sli.
Also, you can sell those 970's and get yourself something like a used Vega 56/64.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1083298-possible-build-issue/#findComment-12726475
@VEXICUS
Tomahwak range is good choice. You will need x470 range if you want SLI.
Magical Pineapples
https://linustechtips.com/topic/1083298-possible-build-issue/#findComment-12726476
Just now, desertcomputer said:
@VEXICUS
Tomahwak range is good choice. You will bed x470 range if you want SLI.
I know that b450 doesn't support sli.
I'd recommend selling one of his 970's.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1083298-possible-build-issue/#findComment-12726480
22 minutes ago, Cookiecrumbles222 said:
i would prefer to keep the sli because it has worked very well for me do you know a good board with sli? or what to look for?
For sli support, you'll need a x470 board.
I'll recommend the following one...
https://pcpartpicker.com/product/NGbwrH/asrock-x470-taichi-atx-am4-motherboard-x470-taichi
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1083298-possible-build-issue/#findComment-12726506
how do i tell the vendor to update the flash bios if im buying on newegg?
https://linustechtips.com/topic/1083298-possible-build-issue/#findComment-12726515
You could do it easily. It's pretty simple.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1083298-possible-build-issue/#findComment-12726756
