Hello guys! I am rebuilding my loop and upgrading a few parts.
I have a dilemma. Does it have a performance impact if at the outgoing flow port of the pump I put a splitter, one way that goes to the radiators and one way that goes to the blocks ? Like having 2 separate loops but on the same pump. It would be easier for me in the loop building. I use hardpiping.
Is that good? Does it affect performance?
Thanks
https://linustechtips.com/topic/1082919-planning-advice-watercooling-loop/
Would have to be the perfect build to not see any real issues. Would still not perform to the best of its ability. You would need a lot of specs and details to work it correctly. Or just send it and do it and see how it goes for yourself.
Works well almost every time I have done it( about 10 times), cpu on 1 loop, gpu and rad(s) on the other, seems to work the best. Improves the system overall flow rate if your blocks are restrictive . Changing over my latest build tonight, thanks for the inspiration!!
