PC set-up:
OLD: Graphic card gtx 960 paired with mobo Asus Maximus VIII Hero with I5-6500, PSU-Corsair 650w & G.Skill Trident X DDR4-16GB RAM 2133 hz. Samsung 480GB SSD & WD 1TB HHD
NEW: replaced gtx 960 to gtx 1660ti, added Kingston A400 480GB SSD & Seagate Baraccuda 7200 1TB
Need some advice for the following;
1. Can the new GPU achieve its full potential with the current set-up? If NOT.  Any suggestion?
2. Ran a benchmark test (refer below link) and found out that the newly added SSD & HHD were not performing to their potential. Any explanation as to why?
https://www.userbenchmark.com/UserRun/18403624
https://linustechtips.com/topic/1082684-cpugpu-bottleneck/
What resolution and what fps target?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1082684-cpugpu-bottleneck/#findComment-12722129
Its 1920 x 1080, 60hz
17 minutes ago, Mira Yurizaki said:
It depends on the game and the settings you're running at.
I play lots of games but I only notice the problem when running games such as Battlefield 1. Whenever I play Battlefield 1, the CPU % reaches up to 100% and the game starts to lag causing stutters with mouse and movements and fps drops. Stuttering also occurs sometimes when I have multiple tabs of chrome open.
https://linustechtips.com/topic/1082684-cpugpu-bottleneck/#findComment-12722163
25 minutes ago, rochjie said:
Kingston A400
This is the worse... lower performance and highest failure rate SSD you can buy brand new right now... bad pick mate, should have asked in here beforehand.
stable 60+ fps.
GTX 1660 Ti should be perfectly capable of very high settings with a target of 1080p60hz, so GPU you're golden.
The i5 6500 on the other hand, there will be games it can keep up the 60fps smoothly (highly advised to use v-sync), however in certain triple A high CPU demanding games such as Assassin's Creed Origins/Odyssey you'll see averages on the mid 40's to low 50's in certain areas of the map. The CPU is borderline between just enough and not enough any more.
You can improve things by ensuring you have a healthy OS and no unneeded background and sideground applications running while you game, sadly even though you have a high end motherboard the only CPU that makes sense upgrading to is the i7 7700 ~ i7 7700K which would solve your issues yes but value wise they are terribly overpriced even second hand.
Personal Desktop":
https://linustechtips.com/topic/1082684-cpugpu-bottleneck/#findComment-12722182
Thanks a lot for the inputs. It's a great help.
https://linustechtips.com/topic/1082684-cpugpu-bottleneck/#findComment-12722419
