Hi folks,
It's finally time to replace the core components of my trusty Sandybridge build, which lasted a solid nine years. I've decided to try and go with mATX this time, since I rarely had more than two PCIe cards in anyway and want to reduce clutter on the desk a bit.
Following constraints on the whole thing:
- use case is 70% gaming and 30% random stuff (Photo editing, programming, playing around with blender or other random projects - but since I cuurrently don't plan on making money on that, seconds of processing time ain't worth much cash)
- I currenly play at 1400p/60Hz but am thinking about getting an Asus MG278Q or similar (144Hz GSync-compatible QHD)
- GPU, PSU and cooling (+ AM4 mount for a few bucks) of the current system will stay, hence listed below with a price of 0,00€
- since I won't use high-end storage solutions, I guess it's not worth to go the X570 route. However, since I don't have a spare CPU and not many shops in Germany offer BIOS upgrade services (Mindfactory charges  34,90 € for that), Bios Flashback functionality is a must for B450 / Z470 boards
- the storage drives listed below are still up for debate, I kinda want to ditch my 2TB HDD for a cheap gaming SSD, since documents are on a NAS anyway and it's just old and low.
Following questions are still open:
- having seen Gamers Nexus review of the 3600 / 3600X / 3700X I'm still debating whether it's worth getting the 3700X and gambling on the future adoption of cores in game engines. Yay or nay?
- since I'm not sworn to any legion - if someone can come up with a comparable Intel build, I'm definitely open to suggestions
- any other remarks regarding the list below.
I currently came up with the following:
Hit me with your best improvements!
Thanks and best regards,
Chris
"We cannot change the cards we're dealt - just how we play the hand" - R. Pausch
CPU: Ryzen 7 3700X , Cooler: BeQuiet Dark Rock 3 Motherboard: MSI B450 Mortar Titanium RAM: 16 GB Corsair LPX 3200 GPU: EVGA RTX2070 XC Storage: Adata 120GB SSD, SanDisk 1TB SDD, 2TB WD GreenHDD Case: Fractal Design Define Mini C PSU: EVGA Supernova 650GS Peripherals: Master Keys Pro S, Logitech G402 Audio: Schiit Fulla 2 + Sennheiser HD 650. Laptop: Asus Zenbook UX 302
https://linustechtips.com/topic/1082386-ryzen-3000-matx-build/
https://www.mindfactory.de/product_info.php/MSI-B450-Gaming-Pro-Carbon-AC-AMD-B450-So-AM4-Dual-Channel-DDR4-ATX-Ret_1266875.html
Swap The motherboard for something like this which has better Vrm cooling and better board all over or maybe even a tomahawk, but slight less vrm cooling there,
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1082386-ryzen-3000-matx-build/#findComment-12719798
Thanks for the input - the linked board is ATX unfortunately.
I was refering to this handy chart of boards and VRM capacity as well as Buildzoids video on the Mortar  which both attest that the board can handle an 8-code just fine. I don't really mind the lack of a dedicated cooler on the VRM for the iGPU / APU at the top, since I don't realllly plan on using the iGPU very much
https://linustechtips.com/topic/1082386-ryzen-3000-matx-build/#findComment-12722275
It’s VRM’s? I run my board with a dGPU. Not sure what’s best on the mATX front. If you’re happy with that then just grab the mortar
https://linustechtips.com/topic/1082386-ryzen-3000-matx-build/#findComment-12722360
