Random network issues please help
Solved by Electronics Wizardy,
3 hours ago, Cherve said:Okay, I ran a command line that I found that said it uses speedtest.net but through the terminal. I got the correct speeds 116mbps down and 6mbps up.
My speeds tanked before I manually updated to that latest version. It is a insider preview version but it was worth a try. I forgot to check what version I was at before updating. It could still be the reason for the issue though. Microsoft needs to test their updates more rigorously so major issues like this do not happen.
Sounds like a software issue then. Id do a reinstall of windows and that should fix your issue. Might be possible to check every little thing, but reinstall is probably easier.
