Hello, I want to build a budget ryzen 3600, will like to purchase a b450 motherboard under 100 usd that doesnt need a CPU to update the bios to support ryzen 3000. Also a good 16gb kit of 3200 or more ram under 100. I need to be sure that all these three parts are compatible and will run at their max speed without any problems. Thank you in advance!
"Who are you the King of Siam, you got to get the best one? Who cares? They’re all the same these machines. They’re all made from the same asian suffering." - Louie Season 3 Episode 10, GO WATCH IT NOW.
https://linustechtips.com/topic/1082039-ryzen-3600-build/
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/1082039-ryzen-3600-build/#findComment-12717471
10 minutes ago, Wingfan said:
I dont think you can update that without a processor though can you? Thats why I went and suggested MSI
https://linustechtips.com/topic/1082039-ryzen-3600-build/#findComment-12717500
aaahh...im not sure ;/
https://linustechtips.com/topic/1082039-ryzen-3600-build/#findComment-12717511
Thank you very much for your replies! I found this website that explains which mobos from msi support the update without needing a cpu: https://www.msi.com/blog/the-latest-bios-for-amd-300-400-series-motherboard
https://linustechtips.com/topic/1082039-ryzen-3600-build/#findComment-12717852
