How the heck did that happen.  That is nasty as if its been under water for 10 years or something.  Just get cotton and use Alcohol.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12710950
This is the first time I am seeing a AIO block oxidize. Was the pump making a lot of noise prior to your removal?
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12710983
7 minutes ago, Thegeekydog said:
Probably shity installation by the company
Thank you for your reply
But also the temps has nothing to do with that.  I think your pump was failing cuz 50c idle is insane under water.  Either that or your rad fans aren't spinning lol which is not the case.  Touch the pump when you power up next, also can you check its RPM ?  You got the double axe in a way sorry for that.  I would look into buying a new cooler and not installing this one cuz 50c don't cut the rug my friend.
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12711028
Pics are too bad, where is the rust exactly?
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12711792
If there's oxidation on the copper water block, its possible it's leaking but I'm guessing your environment is just really humid, or the paste used had contaminated water content, as a leak would probably have been more catastrophic than that.
If the paste was contaminated, then that cold explain the poor thermals.
Or it could be a slight leak and it collected on the block.
Get a better air cooler.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12711879
Did you remove the thermal paste prior to the photo, or was there none to begin with?
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12712093
The pump is working in 4000 rpm but the thing is the temp are 90 Celsius
I put a new thermal paste and it moving the heat to the pump but the water aren't moving the heat from the pump.
What should I do?
Thanks in advance
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12713131
the aio pump is working in 4000 rpm but the thing is the temp are 90 Celsius
What should I do?
Thanks in advance
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12713139
What should I do?
Thanks in advance
stupid quesiton: is/are the fan(s) spinning
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12713143
stupid question: do you have a radiator
Jk ? could you post a pic of the block area? How fast does the temp raise to 90°C? How is your radiator mounted?
3700X | NH-D15 | X470-F | 2x16GB @3200MHz | RTX 2060 Ventus OC
RM650x | Fractal Design R4 | NVMe 970 EVO Plus 512GB | SATA 850 EVO 512GB
<Build Log>
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12713178
What should I do?
Thanks in advance
Sounds like either the radiator cannot dump the heat (its clogged with dust) or the pump has failed.
You should be able to hear the pump if you open the case and listen to is closely.
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12713202
Where is the top-left screw of the CPU block?
Blocks need even pressure to work properly, I think even one missing screw will twist the block a bit which causes it to lose proper contact with the CPU
<Build Log>
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12713285
34 minutes ago, Thegeekydog said:
The screw broke off during installation
This isn't the problem
But that is the problem, you need even force keeping the block flat against the CPU.
<Build Log>
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12713541
I agree with Dubba.
you need any CPU cooler block, HSF or AIO, is properly installed and in complete contact with the CPU.
any gaps will reduce cooling potential of any cooler.
https://linustechtips.com/topic/1081480-aio-pump-not-effective/#findComment-12713581
