Laptop as a monitor
Karate Cop
So I've been searching forums to see if a laptop can be used as a monitor. Not a secondary monitor. Like as a main monitor through HDMI from a desktop PC. Or is that not possible ?
If you're using Windows 10 look into Wireless Projection, it's a built-in feature on Windows 10 and I used it for the first time this week and it worked amazing. The laptop has to be on the same network as the PC, but that's the only requirement.
EDIT: I can't find the guide that I used, but this one should work: https://www.onmsft.com/how-to/how-to-connect-to-a-wireless-display-in-windows-10
-KuJoe
