I have a i7900k Processor, and a RTX 2080. I play minecraft with my younger brother and I prefer installing shaders, as minecraft looks too bland to me lol. However the FPS is very underwhelming. I run the server so I dedicate 1-2 GB of RAM for it, but with Sildur Shaders' I get only 60-100 FPS. Meanwhile videos on youtube show RTX 2080Ti's getting 100+ fps at 4k. I only play at 1080p. The RTX 2080 has been underwhelming. Could there be something wrong with my card, is there anything I can do?
https://linustechtips.com/topic/1080948-rtx-2080-low-fps/
2GB of RAM isn't enough even for the operating system, if you're runnin Windows; so that'll be a big issue for your gamin.  It's more of an issue, if you have more things in the background, such as music, voice apps (discord, ventrilo, etc), web browsers (chrome eats up RAM) w/many tabs, etc.
Primary
OS:        Windows 10 - Professional (64-bit)
CPU:      i9-10900k 3.7-5.3GHz (10th gen)
GPU:      EVGA RTX 3080ti FTW3 Ultra Gaming 12gb
MB:         ASUS RoG Maximus XIII Hero (ATX)
RAM:      64gb (4x16) DDR4-3200MHz G.Skill TridentZ Silver/Black (CL16)
HD:         1x 8TB Corsair MP400 NVMe PCIe 3.0 (SSD)
               2x 16TB Seagate Exos 7200rpm (HDD)
E-HD:     12TB WD
PSU:       EVGA 1000w G2, 80+ Gold (modular)
UPS:       900w CyberPower
Display:   ASUS 27” 1440p/270Hz IPS 0.5ms (XG27AQM)
                Aorus 27" 1440p/165Hz IPS 1ms (FI27Q-P) iGPU
KeyB:      EVGA Z15 (wired)
Mouse:    Logitech G-502 Hero (400/600/800/1000)
Headset: JBL Quantum ONE Gaming Headset
Case:      Cooler Master MasterCase H500P Mesh (ATX)
Other:     XB-1 Wireless Controller Adapter w/Controller
              NPET H01 Gaming Mouse Bungee Cord Holder w/4 USB Ports
Gaming Computer Specs.pdf
https://linustechtips.com/topic/1080948-rtx-2080-low-fps/#findComment-12709226
I meant I have 1-2 GB of RAM for the server. I have 16GB my bad.
https://linustechtips.com/topic/1080948-rtx-2080-low-fps/#findComment-12709229
Have you upgraded from a non-RTX 2080 on this system?
Primary
E-HD:     12TB WD
https://linustechtips.com/topic/1080948-rtx-2080-low-fps/#findComment-12709235
A few things I have tried when my rig underperforms -
-Setting power saving mode to ultra performance (even in a desktop)
-Going into Control Panel of Nvidia to make sure its using the GPU and not the cpu's grpahics.
-Checking overclocks and drivers
-Using RivaTuner (or any other monitoring software) to see utilization and clocks to further see what is throttling/under performing
Hope this helps.
You might also check the minecraft forums to see if there is something preventing your PC from performing higher. As far as I can say, don't blame the card, it shouldn't be "underwhelming"
Edit: one more thing, the minecraft video settings have a setting for fps limit which I reduced without reading it back when I first started playing. Maybe check that too
https://linustechtips.com/topic/1080948-rtx-2080-low-fps/#findComment-12709242
