I bought 9900K from this store called CeX. Seems like they've been scammed and so was I in the process. Thank God for 14 day return policy.
I compared the images of the "9900k" I received vs pictures online (as I didn't want to undo my custom loop to get to my 2nd one that's in use) and there's clear differences.
Could someone help me find out what this CPU is? Cheers.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/1080857-help-identifying-a-cpu/
Just now, RGProductions said:
Short of just popping it in a board I'm not sure much can be done.
Defo won't put it in my board, just in case. I tried comparing to like 6600K etc but it doesn't match.
It looks like LGA1151 but not sure...
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1080857-help-identifying-a-cpu/#findComment-12708344
14 minutes ago, TheNaitsyrk said:
It rather looks like an 8700k
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1080857-help-identifying-a-cpu/#findComment-12708377
Intel
Those three blue capacitors on the left side are higher than two large ones on the right. It doesn't match so it can't be. It's missing a lot of them by design, so I'm suspecting it's one of the cheapest Pentium CPUs. G something.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1080857-help-identifying-a-cpu/#findComment-12708380
Found it. It's Pentium G4500 OEM.
https://www.dns-shop.ru/product/8278306f56913361/processor-intel-pentium-g4500-oem/
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1080857-help-identifying-a-cpu/#findComment-12708389
People don't like taking glam shots of Pentium CPUs unfortunately, hard to find the rear of those.
Although it bares quite the resemblance to a 700k
Image result for i7 8700 back
and also to the 6700k
Image result for i7 6700k back
edit: well nvm
Primary PC:
PSU tier list
https://linustechtips.com/topic/1080857-help-identifying-a-cpu/#findComment-12708391
I already found it. It's G4500 OEM CPU.
Literally someone took the IHS off both, and stuck 9900K IHS on it and sold it as it. Thank God I can return it.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1080857-help-identifying-a-cpu/#findComment-12708396
