What Parts Should i use for my first pc?
7 hours ago, fasauceome said:
Hey i was looking into some motherboards and you seem like you know what you're doing. do any of these look good?
https://www.newegg.com/p/N82E16813157886?Description=x570&cm_re=x570-_-13-157-886-_-Product pretty cheap and has some good features
https://www.newegg.com/p/N82E16813119197?Description=x570&cm_re=x570-_-13-119-197-_-Product cheapest wifi board with some good features but its asus
https://www.newegg.com/p/N82E16813157885 the board you recommended, but its a little on the expensive side
https://www.newegg.com/p/N82E16813145161?Item=N82E16813145161&Description=x570&cm_re=x570-_-13-145-161-_-Product cheap option with less features
id like to keep it under 200, but advice?
I'd save on the mobo and buy a b450 tomahawk, it's abt 100$ less and supports 3rd gen ryzen.
Buy the 1660ti Since the RTX series are still in an infant state and also an expensive one, the rx5700 has problems with gen4 from what i've seen so wait til amd fixes it.
The RAM frequency speeds are good if you go for the x570 but if you go for a b450 due to budget reasons u better go for a 3200 one
Pick up the 650w PSU, gen4 mobos seem to suck a lot of juice.
Thank you for your input. I will consider your suggestions.
1 hour ago, Terminal.exe said:
Of these, I'd pick this one. The Pro4 line has been ASRock's budget champion, usually favoring power delivery over all else.
Primary PC:
Ok cool. tysm
but the steel legend dropped in price. should i get that instead?
Why get a cheap B450 over a X470 that are usually better featured?
The GTX 1660ti is a very slow GPU compared to the RX 5700. The RX 5700 is at its first step and drivers will improve in the next month or two. I wouldn't buy a 1660ti and wait until Radeon drivers are better, just wait for 3rd party RX 5700 cards with better cooling.
Ram speed is related the CPU's Ram controller and the RAM speed itself, i don't think it as a lot to do with the chipset since have don't have enough experience yet with faster RAM on slower CPU/chipset.
Whats is you total budget if you have one?
What do you NEED?
What do you want about your build?
Can you wait to buy parts or you need them ASAP?
Buying cheaper parts right now to upgrade later cost more then waiting to buy what you really want, trust me about that i'm in that situation.
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
A higher end mobo on sale is always a good deal
Primary PC:
The Steel Legend is the entry level board, It's probably a 4 phases with doublers or 4 paralell phases + 2 SOC phases, good X470 boards will have a better VRM. Unless it's very cheap, i needed PCIe gen 4 or needed X570 chipset because i don't own a previous generation CPU, i would get a good X470 over that board.
That's probably a good case for the tomahawk or something with BIOS flashback
Primary PC:
um i’m talking about the x570 steel legend with 10 power phases lol
4 phases times 2 (becauses they use doublers or parrallel phases) equal 8, then you had the 2 SOC phases, thats 4*2+2= 10 phases. Thats how they fool people with their phases. Some doubled phases are worst then REAL single phases, Gigabyte showed that with the B450/X470 chipset.
oh ok. well do you have a x570 recommendation?
What do you really need and what are the features you are looking for? what is your budget?
ok so i’m looking for a good overclocking board cuz i want to crank up my 3600 to its highest potential. looks don’t matter cuz it’s going in a no window case, i’d like it to have a decent amount of usbs, m.2 and if possible wifi. and the budget would be under 200 but under 250 if necessary
If you can afford the top tier X470 boards like the MSI Pro Carbon, the Gigabyte Ultra gaming 7, Asrock Taichi, that would make great boards for you, but I dont know about the pricing where you live. X570 lack of features make me avoid those ''low end'' boards in favor on better featured X470.
If you go the X570 way, you can take a look at Buildzoid review of these boards PCBs, you will the good and the bads of most of these boards.
I think I'm going to go for the steel legend. Cuz of this quote "this model also uses a straight forward 10-phase power delivery and includes an 8-pin and 4-pin set of 12 V ATX CPU power inputs to provide power to the processor." https://www.anandtech.com/show/14161/the-amd-x570-motherboard-overview/9 so yeah. if that quote is wrong ill look elsewhere but I want x570.
Don't get me wrong, but I don't trust those reviewers because they mostly read the Specs on the website and then test these boards with default settings, and there is 3 pages about packaging. Take the time to go see the videos Buildzoid made on YouTube, they are long but very instructive.
ok ill look at some videos.
he has only done asus so far so ill watch his other videos too.
Oh i forgot to mention he made videos for Gamers Nexus that may only be available on their channel because you know.... content creation stuff.
ah ok
On 7/9/2019 at 1:01 PM, Terminal.exe said:
Ok, thanks. And you think I shouldn't get an x570 mobo right?
If you don't NEED Gen 3 NVMe right now, you certainly won't need Gen 4 NVMe in a few years.
B450 is all you need, really.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
So I watched buildzoids video on the asus boards and I think i'm going to go with the x570 tuf wifi board, because it has good power delivery for overclocking, its mid range which is good cuz im only getting a 3600, and it has wifi and other nice features. what do you think?
https://www.asus.com/us/Motherboards/TUF-GAMING-X570-PLUS-WI-FI/
That should do the trick
