i have an i5 9600k,RTX 2080 16gb ddr4 3200mhz msi MPG procarbon z390 with a sata ssd and for some reason my fps is really low for my specs iv test different ram motherboards cpus and my gpu usage clock speed power consumption is all normal but my fps is Rainbow Six Siege:70-100 Insurgency sandstorm:60-80 CSGO:230-280 on a 144hz display
https://linustechtips.com/topic/1079860-low-fps-in-games/
15 hours ago, Metallus97 said:
does not seem that low, but:
Windows up to date?
BIOS up to date?
drivers up to date?
yes its not that low but for the specs and the 144hz that fps is not that good and the drivers are up to date and the bios and the windows
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12700573
Sir, the monitor won't give you any FPS! This is just the maximum it can display. The FPS number you get in games is controlled by your GPU/CPU etc not the monitor.
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12700577
Try reinstall windows or try another drive
Technology is NEVER easy :(
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12700599
i know but what im trying to say is that the fps should be above or around 144 so i can use it fully
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12700664
then you need a better GPU sir. Ocing cn give you a little bit more but you won't hit those numbers in those games with that card
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12700670
this is an rtx 2080 were talking about on 1080p thats not normal fps iv got friends with gtx 1660ti with higher fps
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12700689
Do a speed test here... https://www.speedtest.net/. What is your ping, download and upload?
Is your GPU set to prefer maximum performance?
Is your CPU overclocked? And is it hitting the clock speed it's clocked to in these games?
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12701554
Use MSI Afterburner while playing.
After your session look at the power % graph on Afterburner.
It looks like this.
Your GPU should run at its power limit(target). It will have drops when scenes are less intense and will go over at times.
If you can't maintain the power limit set on your card you are being bottlenecked by your CPU.
If temps go higher than the temp limit your GPU will throttle. Check the GPU temp graph.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12705319
It looks like this.
my max power is 105 while my current power is mostly around 80-100 at 95-100% usage the tempreture is around 63
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12706417
That is a bit low.
What is the max power limit on the card?
The EVGA 2080 ti XC power limit is 130% and its temp under load is from 83 to 84c. My EVGA 2080 ti FTW3 has a power limit of 124% and full out the temps are from 69 to 71c. If either of them where running at 105% they would either be bottlenecked or the power target was set too 100%.
63c is good if you are on water but it is a sign that your card is underperforming if you are on air.
Also if you got the card early it may need a bios update.
https://linustechtips.com/topic/1079860-low-fps-in-games/#findComment-12706667
