VS 2019 Change Project titlebar color.
WillLTT
How can i change the PROJECT titlebar color, and not visual 2019's titlebar. in c# vs 2019 win forms
This is based of your current windows theme. You cannot change it by code. Your options are :
- Change your windows theme to what you like
- use WPF instead of Winform so you can control the look
- use third party control that have custom winforms
- create your own winform control from scratch
- make your form borderless and draw the title bar manually
