pc wont recognize graphic card.
orze
my brother wanted to get a laptop so we wanted to put is pc for sale.
it was only running a i5 3570k
so i went online and got a r9 290 for preety cheap 80$
thing was shown to me as it works and reason it was cheap was 2 busted fans out of the 3.
easy fix really and i allready got 3 new fans that fit this model on there way
thing is this pc wont recognise this gpu..
i tried puting my own 1080 in this pc and it worked fine and then put the 290 in my own rig and that worked fine just as well
so the r9 290 is just not recognised by that pc and i mean notin. only fan spin the pc wont even recognise something is in that slot........any idea why?
cpu: 5950x
mobo: asus tuf pro x570
gpu: 3090 FE
ram: 32gb G.SKILL Trident Z 3200 c14
psu: Antec HCP1300w Platinum (overkill i know...got it for a good price)
thats all needed right?...i didnt study for this exam....
it could be due to the cpu
try re-seating it
i had a dell that had ram slots that wouldn't work cause the cpu was not in properly
try re-seating it
then how it recognized a 1080?...
cpu: 5950x
gpu: 3090 FE
What kind of motherboard are you running? As this is a budget build, I believe it would be possible you are running a 2nd gen chipset right? It would fit your CPU...
We have a friend in Canada that has a i7-2600 (plain) build and he ran into a similar issue. Basically, if you are running an OLD motherboard (and this is pretty much just OEM) sometimes they won't be able to recognize the BIOS format on the GPU. Therefor, it won't work.
I would check your display adapter driver in Device manager and see if it is giving you any error codes. He had one that shot off about not being able to allocate resources. Though that didn't turn out to be correct. (Strictly speaking)
but ill say again....it ran a 1080....why wont it run a 290?
cpu: 5950x
gpu: 3090 FE
Also, DO NOT reseat the CPU, the machine wouldn't work pretty much at all if that was the cause and you would probably see other issues before the GPU problems.
Depends on the bios type on the card. I would suggest checking the device manager for driver errors anyways though. Always a great place to start.
thats the wierd thing it worked ok before...then it sttoped...and as i said...it dosent show up in device manger.
cpu: 5950x
gpu: 3090 FE
an update is i tried installing amd auto detect driver and it said no suppurated hardware....
cpu: 5950x
gpu: 3090 FE
Same thing happened to me once, I updated the BIOS on my motherboard and then it worked. I would recommend trying that.
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 3x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
thats....a great idea.,...and i didnt think of that...
ill chack it right now and update!
cpu: 5950x
gpu: 3090 FE
ok so chacked and im allready running latest bios....
cpu: 5950x
gpu: 3090 FE
Was the PSU the same when you did your check? It's entirely possible that the card isn't getting the right amount of power. If you tried the 1080 and it took more cables then you may have been able to power the 1080 with less than it needs to run games but enough to register in Device manager.
Check the PSU cables and try to swap them.
(Check the PCI slots too)
i gave my guess so i chacked abit more then just startup with my 1080
also its a 730w psu....and a ok 1 at that. 80 plus bronze from rosewell.
so it should be able to run this r9 no problem.
a thing i found wierd is in system config under mb pcie config i see "x0" under pciex16_1
not sure if it means it thinks it got no pcie slots of the video card is just not recofnized here either.
cpu: 5950x
gpu: 3090 FE
x0 refers to the amount of lanes being used from that slot. (I dove really deep into this in the past)
Yes, your Rosewill 730w should be able to handle it no problem. It's a question of whether or not the rails on your 6+2 pin connectors are healthy and giving off the right amount of power. That's why I suggested swapping them.
ill try but again my 1080 ran ok even wan i started a game. cant say i STRESSED IT
but it seem to acted well with the psu. ill try other cables and another connection.
cpu: 5950x
gpu: 3090 FE
Just remember that just because the 1080 ran fine doesn't meant that the 290 will. The 290 takes 275w while the 1080 takes only about 180w. That could make all the difference.
nope....got it on a diffrent connector and with another cable. notin.
im confused cus it worked before.....
cpu: 5950x
gpu: 3090 FE
Does it still work in the other motherboard? No changes there?
Also, you tried it on a different PCI slot right?
1 yes worked perfect on my rig.
2. Only 1 and 1080 worked on it
cpu: 5950x
gpu: 3090 FE
What's the mobo model?
Asus P8h77-mle with a i5 3570k
cpu: 5950x
gpu: 3090 FE
@orze
What GPU was your brother's computer running with BEFORE the R9-290 swap?
nVidia + AMD drivers/hardware together does not mix.
You need to COMPLETELY remove the nVidia drivers (e.g. uninstall then use DDU) before trying the R9-290.
A few years ago, I had bought a GTX 760 for a friend, and decided to test it in my system before handing it over to them. At the time, I was running AMD Radeon HD 7970's (aka R9-280X) in Crossfire. I had no issues uninstalling the AMD drivers, reboot, and simply sticking the GTX 760 into the system. When I wanted to put my own AMD cards back in, the system did not boot up properly. It would crash, and bug out. Turns out, bits of leftover nVidia driver files were causing the issue, even after uninstalling and rebooting the PC. I had to use DDU.
Official D.D.U. download page.
https://www.wagnardsoft.com/
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
2 minutes ago, -rascal- said:
@orze
he didnt had any gpu just stock igpu
not only that i got a new ssd and hdd for this thing and got a new install of windows with NOTIN left from the old pc
(old hdd was on is last lags ticking so we backed it up and is just sitting there doin notin xD)
and again mate....the gpu isnt even recognized by the system as being there...NOTIN like not even a unrecognized device.
cpu: 5950x
gpu: 3090 FE
What is the specific model "730W" Rosewill PSU?
Are you using TWO separate PCI-E 6 / 8 pin power cables for the R9-290, or using a single cable with daisy-chain PCI-E connections?
E.g. This...or two separate cables?
Image result for PCi-E daisy chain cable
AMD Ryzen Rig
  • AMD R7-5800X
