where do i get water cooling liquid
Solved by Votivee,
It comes pre-filled. If you were to break the seal it would void any warranties and probably cause it to leak.
Featured Topics
DrewRomine ·
Posted in Programs, Apps and Websites1 -
VinSen ·
Posted in Troubleshooting2 -
MrZoraman ·
Posted in CPUs, Motherboards, and Memory12 -
4
Ayush008 ·
Posted in Console Gaming2 -
2
pilgr1mag3 ·
Posted in Graphics Cards7 -
hometown odyssey ·
Posted in New Builds and Planning7 -
Mesarasi ·
Posted in New Builds and Planning5
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
