Whats the best card this cpu can handle? I wanted to upgrade pc for years but never decided to do it. Busy, lazy and kinda dont wanna mess with all files, games,  programs that i installed through years. And yet, this cpu does well with gpu that i have but i want try some 4k gaming on 43 screen. I play mostly battlefield  3 these days. Dont wanna get gtx 2080 ti if it will be blocked by cpu.
https://linustechtips.com/topic/1077792-max-gpu-for-i5-3570k/
if you're playing at 4k then you shouldn't really reach a cpu bottleneck with something like a 1080 or 1080 ti
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1077792-max-gpu-for-i5-3570k/#findComment-12685697
If it were me I wouldn't go faster than a 2060.
Main System: EVGA GTX 1080 SC, i7 8700, 16GB DDR4 Corsair LPX 3000mhz CL15, Asus Z370 Prime A, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R5, 2TB Seagate Barracuda, 500gb Samsung 850 Evo
Secondary System: EVGA GTX 780ti SC, i5 3570k @ 4.5ghz, 16gb DDR3 1600mhz, MSI Z77 G43, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R4, 3TB WD Caviar Blue, 250gb Samsung 850 Evo
https://linustechtips.com/topic/1077792-max-gpu-for-i5-3570k/#findComment-12690769
3 hours ago, okar said:
Just run bf3 on ultra with gtx 950 and its not as bad as i thought it would be. ~40 fps. 1080 ti should be just fine?
I mean BF3 is a 2011 game. The best GPU around that time was GTX 580 I think. I'm pretty sure 950 is pretty close to 580.
https://linustechtips.com/topic/1077792-max-gpu-for-i5-3570k/#findComment-12690771
BF games are notoriously brutal on CPU.  Other games, you'll not see a bottleneck of any type going to a 2080ti.
CPU || Ryzen 2700x @ 4.3ghz  Motherboard || ROG Strix B450F  RAM || 16GB TridentZ 3600 B-Die  GPU || ASUS ROG Strix 1080Ti  Case || Thermaltake V71 RGB  Storage || Intel 760p 240GB + Intel 535 480GB SSD + 1TB WD 7200RPM HDD  PSU || Corsair HX850i  Cooling || Corsair H110i GTX  Keyboard || Corsair K70  Mouse || Logitech G502 Proteus  Sound || Bose Companion 5  Operating System || Windows 10 Pro
https://linustechtips.com/topic/1077792-max-gpu-for-i5-3570k/#findComment-12691322
Just depends on the frames the card can make. You can still have an issue with that cpu. But a 1080 should still be over the 100 FPS range at 4K for that game. The card is cheap enough to get it and try or a 2060.
https://linustechtips.com/topic/1077792-max-gpu-for-i5-3570k/#findComment-12691877
  • 1 month later...
GTX 590 if we're getting technical. Keep in mind this is back when SLI was actually worth something.
https://linustechtips.com/topic/1077792-max-gpu-for-i5-3570k/#findComment-12842243
