Good day I am working on using some older hardware to do a build but having a hard time picking a GPU as I was unsure how this system would stack up for gaming in 2019 it will be a spare system for the kids to use for 1080P gaming no 4k or any thing like that.
System specs:
MB: XFX 750i-72P9
CPU: Q9400
RAM: 8GB OCZ 2N800SR
SSD: Samsung 860 EVO 500GB
HDD: Seagate 2Tb
https://linustechtips.com/topic/1076431-gpu-help/
Very poorly, what games is this thing going to be handling? I recommend something like a GTX 760/950.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1076431-gpu-help/#findComment-12675168
the CPU is very unfit for 2019 gaming, you're gonna have a bad time
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1076431-gpu-help/#findComment-12675171
Without a graphics card? Nah it's bad. Even with a graphics card (say a RX 560) it's still ill suited for anything demanding. I guess esports games (and others of similar hardware requirements) are what it can reasonably play at most.
Desktop benching:
https://linustechtips.com/topic/1076431-gpu-help/#findComment-12675176
System specs:
MB: XFX 750i-72P9
CPU: Q9400
HDD: Seagate 2Tb
As someone who deals with older hardware and games on it, that system wont be amazing, as for a GPU you could run it in, I'd say at most a GTX 960/760 or an AMD r9 270 which is my current GPU. You'll be CPU bottlenecked with any card like these but the games you can play will be decent, Fortnite, Minecraft, Apex, etc in that 60-90 fps range on medium settings at 1080p. You really shouldn't expect much, and upgrade that CPU if possible.
https://linustechtips.com/topic/1076431-gpu-help/#findComment-12675196
Probably something like GTX 960/1050/1050Ti from nVidia and I dont know about AMD but a RX 550/560 from the newer ones should be good but I suggest waiting and upgrading your whole system because Core 2 Quad is really not enough for gaming (at least more than 30fps) in 2019
https://linustechtips.com/topic/1076431-gpu-help/#findComment-12676972
I picked up a R9 280X for 35.00 just needed new fans not to hard of a fix the system seems to run well with the X5482 it is hitting 60+ fps on med / high setting should work well for the kiddos thanks for all the help
https://linustechtips.com/topic/1076431-gpu-help/#findComment-12681141
