Hello
Today I read some new info regarding the vive cosmos
The screen is 2880x1700 pixels, or 1440x1700 pixels per eye
LCD panels
6 camera's for inside out tracking
price  below 900 USD
sources:
https://newatlas.com/htc-vive-cosmos-vr-headset/60305/
https://www.roadtovr.com/htc-vive-cosmos-price-release-date-rumor/
AMD 5900x, 2x16GB ( G.skill F4-3600C16 ), Radeon VII, Radeon 570,  Corsair 1200i , SSD 240/500GB, HDD 640GB,1TB,5TB, 1TB NVME. Lian li 011Dyanmic XL, big ass LTT mouse-pad & stealth water bottle
https://linustechtips.com/topic/1076205-vive-cosmos-info/
There is or was a company that is experimenting with projectors.
Instead of displays you got a projector and a reflector pointing towards a ' screen'. This was supposed to mitigate the screendoor effect.
I can't remember any more details than that though.
https://linustechtips.com/topic/1076205-vive-cosmos-info/#findComment-12673527
4 hours ago, VegetableStu said:
... you know, I wonder why hasn't anyone played around with using optical fibers to make a display in the headset (so the emitting screen can stay flat and elsewhere, while the main visual surface can be curved and also bend towards the extreme edges of peripheral vision ._.)
Expensive as heck
And weight
And a pain in the ass for not much gain.
A curved OLED display would be 100000x better and simpler
https://linustechtips.com/topic/1076205-vive-cosmos-info/#findComment-12673821
25 minutes ago, VegetableStu said:
are ellipsoidal/spherical panels possible? o_o
Ellipsoidal yes,  spherical, don't know but might be depending on the diameter.
https://linustechtips.com/topic/1076205-vive-cosmos-info/#findComment-12673875
