Okay, so came home today and my PC wont boot, goes directly to BIOS
Its a MSI PC mate board and it (should) boot from my M2 Nvme Mp500 drive, it wont.
IT detects it, aswell as the other drives.. refuses to boot tho, tried a usb with W10 aswell, nothing.
Checked the BBS priorities, not a problem...
Getting a feeling my board is faulty, even tho it detects and Works fine in BIOS...
Any tips?  IMG_20190625_155313.thumb.jpg.288ed438ffcafdc67e6c46bfca384668.jpg
*Edit
Its detecting the M2 drive, but just says PCI-E device [Remapping]
https://linustechtips.com/topic/1075946-help/
1 minute ago, Majazzleren said:
Then why wont it boot from a usb either?  Seems a little odd
Pull m.2 stick, then try the USB stick.
You are certain the USB is bootable?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1075946-help/#findComment-12671192
Have you cleared CMOS just in case that was a bad Motherboard behaviour, this kind of sh*t happened to me with unstable BIOS update.
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
https://linustechtips.com/topic/1075946-help/#findComment-12671240
