Hey guys I need some laptop recommendations,
I need two laptops both with relatively long battery life and somewhat durable as they will be going to Africa and under 1k each:
1 - An accounting laptop with network Jack and a large screen, 8gb ram or more. Long battery life so it works during power outages and easy to take apart or something to maintain for the large amount of dust.
2- A laptop to monitor security cameras, vehicle tracking and some mechanic work. Must also have a long battery life, 8gb ram or more, networking jack but the screen can be 15 inches not.more. Maybe a bit stronger graphics card.
The more rugged the laptops are the better but I'm trying to spend under 1k each.
I have all the sources to buy the laptops here in the US, so Amazon, Walmart etc.
https://linustechtips.com/topic/1075802-need-recommendation-for-2-work-laptops/
I'd say a Thinkpad E595 would work great for both of those tasks. If you want a better screen just up the price by $30 for the 1080p panel. Both are under $600 in there stock configuration.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
