Hey, I do have a odd issue. Asus z390-i Board, using on-board RGB Controller, The Regular Leds in case works fine. But the Leds on the water cooler is addressable. but I can never get them to match color. Still using the ASROCK RGB Sync program with the computer. If I change the color in the program to blue, it goes to green. green to red.. etc. It never matches the color that I want it to be. What am I doing wrong?? btw Fresh clean install of windows 10 with updated drivers.
Any Help would be  appreciated.
Red.
https://linustechtips.com/topic/1075552-a-fairly-odd-issue/
Why are you using ASRock software with an Asus board?
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1075552-a-fairly-odd-issue/#findComment-12668011
3 minutes ago, Redash said:
I looked into the case, It looks like that the water cooled RGB is setting in the only addressable slot on the board.
then try plugging it into the rgb controller if there's room for it. i assumed it was already connected to the controller
https://linustechtips.com/topic/1075552-a-fairly-odd-issue/#findComment-12668033
