I've just bought a Gigabyte RTX 2080 Windforce OC card and it was doing an annoying revving thing with the fans which is apparently a known issue.  I updated the firmware but it didn't resolve it.  I got the card at substantial discount, so returning it didn't seem to make much sense.  In order to resolve it, I whipped the fan shroud off and cable tied two 120mm Noctua fans to it... janky isn't the word, but it works surprisingly well and it's way quieter than the stock fans and no hateful revving.
I got to thinking that I could put one of those custom heatsinks on the card (I don't want to water cool it for a few different reasons) but I can't seem to find any specifically for the 2080.  There was the Raijintek Morpheus II but it only seems to support the 1080Ti.
Anyone using a custom heatsink on these things... or know of one that would be compatible?
Thanks <3
https://linustechtips.com/topic/1075225-rtx-2080-custom-cooling/
LOL i did that for my 970 windforce after the fans broke, works better than the stock fans, iirc thats a reference pcb, so check if any1's used any hybrid cooler designed for the founders edition  (very common) on it
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
