Hey
So I finish building my first pc this Christmas and it ran fine for a month then it started shutting down randomly and not turning back on unless unplugged for a bit I heard this was due to AMD’s problem with the cpu being under volted. So I lived with the occasional shutdown. yesterday I was on it and it was running fine I ran a cinebench and got the same performance I had when I built it 1556cb. Today went to get on and work on cad and it wouldn’t boot so I unplugged it for awhile when I turned it back on it started to boot “nothing on screen” and it shut down again and did this over and over again. I unplugged it and reseated everything and checked all connections then turned it back on and still it’s in a loop of off and on.
If anyone could help thanks.
AMD Ryzen 7 1700x
Rx580 8g gigabyte
3200 Trident Z 8g x2
Asrock AB350 pro 4
seagate 2tb barracuda
Rosewill phantom 650w gold
kingston 120g ssd
https://linustechtips.com/topic/1074937-boot-loop-help-please/
59 minutes ago, Camlh said:
Hey
AMD Ryzen 7 1700x
Rx580 8g gigabyte
Asrock AB350 pro 4
kingston 120g ssd
Can you get into UEFI by pressing F2?
https://linustechtips.com/topic/1074937-boot-loop-help-please/#findComment-12663175
