Help with ethernet in the home
Bradders
So my parents renovated our house and they got ethernet access points put in some of the rooms. I'm not quite sure how to get them to work, they all terminate at one point in the house (next to the wifi router/modem that we got from BT) now from what I understand I might need a network switch to make all the ports work and then plug that into my router? Im not quite sure and could do with it explaining a little.
I welcome any help at all and would be super grateful.
- SSUPD Meshlicous - Z170I - i7-6700K - Gigabyte 2080 - 16GB Corsair Vengance - 850 EVO 1TB - H115i ICUE Link- SF600
You might not need a switch at all if your router provides enough ethernet ports to supply the amount of ethernet compatible devices in the house.
If a switch is needed I recommend this https://www.amazon.com/SYSTEMS-10-Port-Gigabit-Managed-SG35010K9NA/dp/B01HYA36SG/ref=sr_1_1?keywords=cisco+small+switch&qid=1561045342&s=electronics&sr=1-1
It is an easy setup and CISCO is one of top rated networking companies in the world.
oh perfect!, that would be fantastic if I don't, thanks so much. I'll be checking exactly how many ports I have tomorrow and how many are free on the back of the router
12 minutes ago, TheShawnMiranda said:
If you do need a switch, you can get an 8-port Gigabit switch for $20 or less on Amazon. Anything unmanaged by Netgear or Cisco should work great!
Can confirm, I have a TL-SG108 that just does whatever it has to, even if that means full gigabit transfers for hours on end.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
You, sir, should upgrade to terabit ?
