Can I get some context?
Did you buy a new AM4 chip? Do you have the stock cooler? What chip is it?
https://linustechtips.com/topic/1073490-best-cooler/#findComment-12650676
i have a i5 4430 and the stock cooler flimsy attachments devices broke so it wont go on. im wanting to upgrade to am4 in about a year or more so i need future compatibility
https://linustechtips.com/topic/1073490-best-cooler/#findComment-12650683
1 minute ago, KieranTHeBesT said:
its also needs to have thermal paste with it
Most coolers come with thermal paste nowadays.
What case and ram are you using?
Where are you shopping / located?
https://linustechtips.com/topic/1073490-best-cooler/#findComment-12650710
4 hours ago, KieranTHeBesT said:
 cad alberta i can order online
https://linustechtips.com/topic/1073490-best-cooler/#findComment-12651071
