i9-9900k does not boost to 5GHz anymore
2 hours ago, Arucad said:I tried but nothing changed.Tried just one or combination of the C. I've returned them to Auto(which I believe is also "Enabled"), and I sometimes see x49 multiplier, but never under load.
Any load comes in and they all go x47.
Working as expected.
In windows you are never going to see the x50 multiplier with turbo boost and rarely the x49 multiplier when at load. Windows task scheduler constantly shifts tasks between different threads and there are background processes also running on more than one thread. This interferes with turbo boost.
If you use Throttlestop 8.70+ to monitor clock speeds (instead of HWinfo64) and set it to "More data", you may see your x49 or x50 more often. I don't think HWinfo64 will update faster than 250ms per poll.
If you really want to see the higher ratios active at lower loads, you need to run something like Linux.
