Pin 16 voltage?
Go to solution Solved by badreg,
Short 16 and 17 with a paper clip.
https://gpushack.com/blogs/news/43997828-psu-paper-clip-test
Pin 16 will need to be jumped to any black pin below to switch the unit on.
This can be done with a paperclip, twist tie wire, or even a fork, although I'd not suggest using a fork.
https://linustechtips.com/topic/1072905-pin-16-voltage/#findComment-12646278
  Reveal hidden contents
Ya I had that diagram, it just didn’t have the actual input needed for pin 16, and ya I’ll pass on the fork lol
https://linustechtips.com/topic/1072905-pin-16-voltage/#findComment-12646282
