Cleaning graphics card help
1 hour ago, Naxy said:This is the link to the information about my GPU https://www.evga.com/products/specs/gpu.aspx?pn=e466f076-3e8f-4825-b4b0-f1863e893972
For the thermal paste, I do have some ARCTIC MX-4 Thermal Paste. Would that work or do you need a different kind for a GPU?
Also, I have watched that video before I noticed he used alcoholic wipes for the board of the GPU, is that needed? Like I do have some isopropyl alcohol 99%. Could I just dab some on a microfiber cloth and then wipe the board?
Thanks!
-MX-4 is fine.
-Dabbing Isopropyl Alcohol on a microfiber cloth is actually better than using alcoholic wipes, so I’d recommend that.
-If you live in a humid environment you might need wet cotton swabs to get in some nooks and crannys, because the dust will be slightly moist and stick to the GPU
