So i am making  a program with python
and i have defined an option, but it shows up as not...
option = input("Select your language: lan1/lan2")
if option == "lan1":
    menu1()
elif option == "lan2":
    menu()
else:
    print("Wrong option")
def menu1() :
    print("Soon")
def menu() :
    #stuff
https://linustechtips.com/topic/1071464-unsolved-reference-in-python/
Might not be the problem but the interpretor reads top to bottom so you should move you functions to the top.
Shouldn't use functions before they are defined.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Still doesnt work
def menu1() :
    print("Soon")
def menu() :
    #stuff
    menu1()
    menu()
else:
Just now, Zuccers said:
Still doesnt work
It may be the hitting enter is also adding a new line char to the input?
Have you printed out input to see what it contains?
