I reverted my i7 5820k back to stock this week, never fully utilized stock speed with it OCed it only added more heat to my room. While i was stress testing my cpu with intel extreme tuning after messing around with cpu fan curve to see how it was doing. I noticed in H/W monitor my core #5 reached 3.6ghz turbo speed while the rest of 5 cores only reached 3.4ghz. Is this normal to have one core higher than the rest?
https://linustechtips.com/topic/1071242-different-core-speed/
what about hwinfo64? HWmonitor tends to misread stuff
Desktop benching:
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12631637
3 hours ago, winkawak said:
it doesnt show all 6 core speed/temp like hwmonitor
scroll down, it will show it somewhere.
but as far as I know X99 can indeed run different multipliers on different CPU cores.
Desktop benching:
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632767
sorry i got realtemp confused with hwinfo64, i downloaded both
btw whats the difference between realtemp/realtempgt/i7turbogt?
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632811
No idea, Hwinfo64 does everything they can so I dont see the point to let those take my storage space
Desktop benching:
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632821
Kinda sorta. Overclocked, Haswell-E doesn't officially support different multipliers on different cores. Broadwell-E does.
But looking at those speeds, I don't think his system is overclocked. 3.6GHz on one core, that's the turbo speed of the 5820K...
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632851
maybe Haswell-E can do it at stock settings, just like 2nd gen Ryzen?
Desktop benching:
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632889
That's basically what I said. Haswell-E can't do it overclocked.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632893
so you're implying that Haswell-E can do it stock? "Because OP removed the overclock already
Desktop benching:
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632896
Yes.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632899
Okay so i ran the quick stress test again with hwinfo64 and its displaying all cores at 3.4ghz unlike hwmonitor. I guess its not as accurate as i thought it was and holy crap does hwinfo64 shows a ton of info i never knew existed. Yea my cpu is stock right now, any reason why its only 3.4ghz? when it says turbo speed stock is 3.6ghz?
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12632923
@Drak3 @Jurrunio
The max turbo for the 5820k varies depending on the load. 3.6ghz for 1-2 cores and 3.4ghz for 3+ cores. https://en.m.wikipedia.org/wiki/List_of_Intel_Core_i7_microprocessors#.22Haswell-E.22_.2822_nm.29
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12633005
because all core turbo is often lower than the specs sheet say. The max turbo isn't reached on all cores.
3 minutes ago, WoodenMarker said:
@Drak3 @Jurrunio
we're talking about different cores running different frequencies in the same CPU.
Desktop benching:
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12633011
That's.. what I just said.
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12633019
You made it sound like the old kind of turbo
Desktop benching:
https://linustechtips.com/topic/1071242-different-core-speed/#findComment-12633021
