So, the computer used around my house is a family computer. It's a pretty over the top system (although, no discrete GPU) for what my parents intended to use it for. Intel i7-8700K, Asus Strix Z370-E, 16GB 3000Mhz DDR4 (dual channel), but not much else.
Earlier today, my brother was on this playing Fortnite (I don't play it personally, he mostly uses it). Fifteen minutes into him playing, we got a BSOD with a SYSTEM_SERVICE_EXCEPTION error, saying that dxgkrnl.sys failed.
Computer restarted and booted fine, but where should I look to fix the problem?
https://linustechtips.com/topic/1071000-help/
It's a DirectX fault, I wouldn't worry about it too much now however if the problem persists I would look at ways on how to fix it.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/1071000-help/#findComment-12629873
Like he said but if it does persist here are a couple helpfull links to said problem
https://blog.pcrisk.com/windows/12289-how-to-fix-directx-errors
Or
https://answers.microsoft.com/en-us/windows/forum/all/directx-issues/7fa47fc8-0c26-4dce-8119-67ffc30edc6d
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
    Corsair pro rgb 16gb 3400 oc stock timings
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
    My digital ssd 250gb pro m.2 (boot) 2tb berracuda 7200rpm +Toshiba x300 4gb 7200rpm
  • PSU
    Evga g3 750
https://linustechtips.com/topic/1071000-help/#findComment-12631217
