Hi
I was wondering if its worth upgrading my gpu, I am currenlly gaming on a 1440p 144H Monitor
Current setup
i7 8086k
16 GB 3200 Ram
Z370E Asus mobo
Zotac 2060 GPU
PSU Corsair AX860i
My Budget is enough for a 2080 or Radeon VII. although I prefer getting what I need for the monitor and not more as I keep upgrading every couple of years
Reason Im upgrading is I got a great deal selling my 2060 GPU
Thank you
https://linustechtips.com/topic/1070818-gpu-upgrade-need-some-help/
4 minutes ago, Camelsmaycry said:
Hi
Current setup
i7 8086k
16 GB 3200 Ram
Z370E Asus mobo
Zotac 2060 GPU
PSU Corsair AX860i
Thank you
If you just get a 2080, you can save GPU money in the future, as a 2080 will last you a long time.
But a 2070 is viable too, since you said you don't want to spend too much.
I wouldn't go for the Radeon VII because of power consumption reasons, but it's your choice overall
Hope I helped!
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
What monitor you got? If freesync/gsync is not a factor, the 2080 or VII are similar in performance. The 2080 has RTX, the VII has 16GB of HBM. Honestly the HBM sounds cooler to me, but RTX has its appeal
Primary PC:
PSU tier list
How many watts do I need?
I think my monitor is the ASUS ROG Strix XG32VQR ( Not sure cause I see more than one model with the same specs kinda) but its the 32 inch 1440p 144 Hz
That model has Freesync so it would work with the 2080 or the VII really well
Primary PC:
PSU tier list
Hope I helped!
Thank you
Personally, I love my 2080... RTX is cool, and it will only get better. Its not a huge game changer right now, but the tech is incredible and WILL make an amazing difference in the future. That said, the 2080 won't be the card to make that "huge difference". Cards down the line with great ray tracing ability will. That said, its cool to be a part of that tech tree and see what it can do. Honestly, even at low ray tracing settings in BF V I think it truly looks fantastic!
19 hours ago, Camelsmaycry said:
Gaming Daily- Some Animated video, editing maybe a few times a year
When you talk about animated video, if you are talking about rendering/ animating this video, then I recommend the Radeon 7 with it's 16GB of HBM2 (twice the VRAM and faster VRAM), otherwise I would recommend 2080.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
Thank you
Thank you
