Hello I have no idea why but, when I play to someting I have low GPU usage (maximum 28%)
Benchmark, 98%.
Yes ALL my drivers is updated.
I play at 1080P
Thank you
AMD - Ryzen 5 2600 3.4GHz 6-Core / Evga 1070ti ftw 2 8 gb/ MSI B450 tomawack / Stock cooler/ G.SKILL 16gb 3000mhz RGB / 860 evo 500 GB /  XL2411 144HZ  / Western digital blue 1 TB 7200 RPM/ Corsair 760T (white) |Window 10 pro
https://linustechtips.com/topic/1070674-low-gpu-usage/
23 minutes ago, Fr4nt1s3k said:
EDIT: Sorry, just read the footer build.
But these questions stand:
When is your GPU usage low? Do you play games?
What is your monitor? 60hz? Do you have V-Sync ON in games?
Yes play games.
144Hz, and nope
https://linustechtips.com/topic/1070674-low-gpu-usage/#findComment-12627714
If you run some kind of brutal benchmark like furmark does your GPU get fully utilised?
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/1070674-low-gpu-usage/#findComment-12628713
yes
https://linustechtips.com/topic/1070674-low-gpu-usage/#findComment-12638078
