Hi all, first time PC builder here, I played around on PcPartPicker for a little bit and did some research on potential parts and I think I have a build at the moment but would love feedback and advice.
I'll be using this pc for gaming, but I'm not quite looking for 4k or VR capability.
This build comes out to USD 1176.40 with Windows 10 included, but I'm trying to keep costs at 1200 or below. I’ll be using it for gaming as well as web browsing/videos/school work. As for games, I want to be able to play a wide variety like Minecraft, Far Cry, Overwatch, Call of Duty, etc.
CPU
AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor
CPU Cooler
Cooler Master - Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler
Motherboard
Asus - TUF X470-PLUS GAMING ATX AM4 Motherboard
Memory
Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
Storage(s)
Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Kingston - A400 240 GB 2.5" Solid State Drive
GPU
Zotac - GeForce RTX 2060 6 GB GAMING AMP Video Card
PSU
EVGA - SuperNOVA G2 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Case
Corsair - Crystal 460X RGB ATX Mid Tower Case
I have the necessary peripherals in terms of keyboard and mouse and a monitor and I won't need any optical drives, but any other things you think I may need are welcome!
https://linustechtips.com/topic/1070652-first-pcpart-picking/
Most gaming won't fully utilize all 8 cores, unless you're gonna stream the higher clock speeds of the 2600X would serve you better.
Better SSD that is NVMe
Meshify C has great airflow to feed the Ryzen's stock air cooler
The G2 is good choice, either way with the RMx or G2 you can't really go wrong
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor  ($179.79 @ OutletPC)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($109.99 @ Amazon)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($66.89 @ OutletPC)
Storage: HP - EX900 250 GB M.2-2280 Solid State Drive  ($33.98 @ OutletPC)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: Zotac - GeForce RTX 2060 6 GB GAMING AMP Video Card  ($359.99 @ Newegg)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($84.85 @ Amazon)
Power Supply: Corsair - RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $985.37
Generated by PCPartPicker 2019-06-07 09:53 EDT-0400
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1070652-first-pcpart-picking/#findComment-12627061
Storage: HP - EX900 500 GB M.2-2280 Solid State Drive  ($57.99 @ Amazon)
Storage: Seagate - Constellation ES 3 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: Sapphire - Radeon RX VEGA 64 8 GB NITRO+ Video Card  ($399.99 @ Newegg)
Power Supply: be quiet! - Pure Power 11 600 W 80+ Gold Certified ATX Power Supply  ($79.90 @ B&H)
Total: $1029.39
Generated by PCPartPicker 2019-06-07 10:16 EDT-0400
This is just better.
https://linustechtips.com/topic/1070652-first-pcpart-picking/#findComment-12627105
4 hours ago, Axiom99 said:
Wow thank you guys, I’ve been hearing a lot about NVidia releasing some new cards at E3 this year and something about an AMD Zen2? Is that something that I should wait until July and look at as well?
It's worth waiting and seeing, for Zen2. For Nvidia, I doubt it's worth waiting for. If you wanted something now, for gaming:
The 9400F will beat out the 2700 in gaming loads. The RTX 2070, while it isn't a great value from price/performance, it's still better than the 2060 and it fits in the budget. I'd definitely stick with RTX for Ray Tracing hardware in the wake of PS5 announcements supporting dedicated Ray Tracing hardware. I fit in a bigger and better SSD as well.
https://linustechtips.com/topic/1070652-first-pcpart-picking/#findComment-12627742
