Hi all
I am trying to build a custom case here, my concern is that if I use metal material ( like many of the aftermarket cases), will it messing with motherboard due to its electric conductivity? Do I have to treat it with something like insulation paint ? the unit will be grounded properly via PSU and I do have the brass motherboard standoff, but not sure if that helps though.
Thinking of use stuff like those:
https://www.homedepot.ca/product/paulin-24x48x-063-bright-alum-tread-plate-/1000861567
https://www.homedepot.ca/product/gladiator-ez-connect-30-inch-w-rack-with-four-15-inch-d-shelves-in-hammered-granite/1001124533
I did build a few pc but never go to this kind of unconventional and electrical area.
Appreciate for any ideas/lessons
The issue comes when the PCB traces/solder points get in contact with conductive material while you have juice flowing through it.  If you have standoffs, and are just creating a case like a case should be made - you are fine.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
As long as none of the solder points on the motherboard or any other board are touching the chassis, it's fine. Though there are certain exposed bits of metal that are fine if they come in contact with the chassis, like the metal surrounding mounting holes or the shielding around ports.
Ok one of the dumbest things I've done...so I bought a new case for my first ever build. And I open it up on the floor in my bedroom with carpet. And then my cat climbs around in there. So I've dusted out all the cat hair and dirt...Is there anything else I need to do before I start building to make sure nothing shorts out?
Nah you are fine. It’s not that stupid actually :P. Just to be safe you can mount your PSU into the case first and plug it into a wall outlet. It will be grounded then.
