65 is great, anything less than 80 Celsius is ideal.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1070086-ideal-2700x-temp/#findComment-12622366
It's not terrible, but it's not awesome.  I'm assuming it's the stock cooler?  If so then you're going to be able to go lower with a better cooler though it isn't necessary unless you want to ring out some more performance.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1070086-ideal-2700x-temp/#findComment-12622491
51 minutes ago, NotGonnaGetWhoooshed said:
I get about 65 degress while playing games like Rainbow six siege and PC Building simulator. Are these temps good? What's ideal?
you are sweet ! great temps that, assuming under full load with stock cooler
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1070086-ideal-2700x-temp/#findComment-12622494
I do not have a stock cooler, I have a thermaltake riing 12 cpu cooler
https://linustechtips.com/topic/1070086-ideal-2700x-temp/#findComment-12622545
Ahh then it sounds like you're doing fine.  And my logic is that improved cooling is leading to higher frequencies which is also pushing temps.  So at 65*C you're probably running faster with that cooler than if you were using the stock cooler.  All of this to say is that you're doing well.
https://linustechtips.com/topic/1070086-ideal-2700x-temp/#findComment-12622554
