18 hours ago, The321 said:
how can i know which connector is an rgb one? Does it always say it in the name next to the connector?
Left is the RGB header, right is the fan header
Image result for fan header vs rgb header
Fan headers will always have those extra tabs to help you align it on the motherboard. The RGB headers on motherboardsare also different and can help you identify which plug goes where.
  • 1 month later...
On 6/1/2019 at 9:04 PM, The321 said:
Soo i have a masterbox lite 5 with 3 of those rgb fans but i dont have the rgb controller. Can i still use the rgb and set all the fans  to a color? There are 4 in Total
Maybe I'm a little late, but if you plug them in you should be able to control them with you motherboard's software, I have the same case and I use the MSI Gaming App
(since I have an MSI motherboard)
First what motherboard you have?
Second the case comes with the LED controller that hooks up to your reset button to change colors if you do not have this you can buy them online.
It’s called Cooler Master Wired RGB Controller C10L 3 compact LED controller for RGB Fans, preset colors, lighting, Brightness Modes about $10.FF814D6A-50E9-4220-A6C0-93E76B7A360C.jpeg.60d851a933e3badb29ccac5d9b3aac14.jpeg
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
