I'm making this post because I'm worried that when I buy all these parts some unknown problem will happen. I already had a 500g SSD and a 1tb hard drive that's why they are not added.
My main questions are
- Will the CPU or GPU be bottleneck in anyway
- Is they any super glaring issue Im missing since this is my first PC build.
Thanks <3
https://linustechtips.com/topic/1068631-first-pc-build/
It's alrightish for the most part... the DS3H is a relatively low end board but should hold up...
For Ryzen you need at very least 3000mhz, if you use 2133mhz you'll severely cripple it's performance.
At least grab the Ryzen 5 1600 if you want to use a RTX 2060, you'll get 2 extra cores that will be of good use.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1068631-first-pc-build/#findComment-12610225
Thanks ❤️
What is your budget for this build?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1068631-first-pc-build/#findComment-12610233
Is it better now ?
Just noticed that case will take 4 weeks to arrive so im going to look for another case in that price range
https://linustechtips.com/topic/1068631-first-pc-build/#findComment-12610240
24 minutes ago, Hannerz said:
700-720£
A little over budget, but with better motherboard and newer cpu.
Mass another £5 and you have a much better quality PSU
Although the 7th of July zen 2 is being released and this will push prices of zen+ down at first. Not sure if you need a pc right now, or could wait
https://linustechtips.com/topic/1068631-first-pc-build/#findComment-12610263
Replace that screenshot with a pcpartpicker.com list so people can copy and modify it, as well as read it easier on mobile and stuff. You'll also get better pricing on your components.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1068631-first-pc-build/#findComment-12610268
Its actually costs 728 on amazon on 707
https://linustechtips.com/topic/1068631-first-pc-build/#findComment-12610279
With Ryzen I would look at 3000 MHz memory for sure. I would either pair the Ryzen 5 1500X with a GTX 1660ti or upgrade the CPU to a Ryzen 5 2600X and stick with the RTX 2060. Might be worth waiting for the Ryzen 3000 series next month too.
CPU i7 8700K ( 5 GHz) RAM G Skill Trident Z 32 GB (3200 MHz) GPU EVGA RTX 2080 XC Ultra Motherboard Asus ROG Strix z370 E Gaming Cooling NZXT Kraken x62 R2 PSU EVGA SuperNova 650 W 80+ Platinum Storage 500 GB Samsung 970 EVO NVME M.2, 1TB Samsung 860 EVO M.2, 1TB Samsung 850 EVO SATA, 1TB Samsung 860 EVO SATA Display Dell QHD 144Hz 27'' Case NZXT H500 Black Keyboard Corsair K95 RGB Platinum Mouse Logitech G900 Operating System Windows 10 Pro
https://linustechtips.com/topic/1068631-first-pc-build/#findComment-12610728
