Would my build work?
Go to solution Solved by trevb0t,
26 minutes ago, ki8aras said:
it really depends on your workload
if you're planning on gaming for most of the time then the i9 is just a waste of money
22 minutes ago, Oalei said:
Yes it will but it will be a bad build if what you're doing is not around the I9 9900K
To clarify: The i9-9900K offers very little gaming boost over an i7-9700K or even 8700K. Its extra power lies in workload processing. So if this is a gaming computer, the extra spending may not be worth it.
The RTX 2060 is weaksauce for an i9 build. An i7 and an RTX 2070/2080, Vega 64, or Radeon VII would be a steady performance boost for gaming.
What are you using the PC for specifically, and what country are you in? We may be able to assist in smoothing the edges.
Hey guys,
Im pretty new with building systems myself so I would appreciate your advice.
ATM I am rocking a 4 year old failing laptop and it is time for a decent desktop.
So heres my go at it:
-Intel Core i9-9900K - Processor
-Gigabyte Aorus GeForce RTX 2060 Xtreme 6G - Grapicscard
-ASUS ROG STRIX Z390-H GAMING - Motherboard
-Corsair Vengeance LPX 2x8GB 3000Mhz- Memory
-CoolerMaster MasterLiquid 240 -CPU cooler
-Cooler Master V Series V550 -Power supply
-Samsung 860 EVO 500GB - SSD
-Samsung 970 EVO Plus 250GB - M.2 SSD
-Intel Optane Memory Series - M.2
-Fractal Design Meshify C - Towermodel - Case
-Corsair ML Series ML140 Premium Magnetic Levitation- Case Fans
Total price 1740 euro
https://azerty.nl/basket/?code=YToxMTp7aToyNjQzODg0O2k6MTtpOjI3NTY3NTM7aToxO2k6MTQzMDQ0MTtpOjE7aTo3MTEwODtpOjE7aToyMTA2MTI3O2k6MTtpOjI3NjUxODM7aToxO2k6MjM1ODY0NjtpOjE7aToyNDQ2MDU1O2k6MTtpOjE2NTgxNzE7aToxO2k6MjYzOTQzODtpOjE7aToxMzc2NTc7aToxO30=
Would this build work? and if it does what would you change?
Thanks,
Xnl hunter
https://linustechtips.com/topic/1068322-would-my-build-work/
9 minutes ago, xnlhunter said:
Hey guys,
Thanks,
Xnl hunter
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1068322-would-my-build-work/#findComment-12607816
https://linustechtips.com/topic/1068322-would-my-build-work/#findComment-12607862
47 minutes ago, xnlhunter said:
Hey guys,
Thanks,
Xnl hunter
You might want more than 550watts
https://linustechtips.com/topic/1068322-would-my-build-work/#findComment-12607884
It's primary use is for cad and gaming
https://linustechtips.com/topic/1068322-would-my-build-work/#findComment-12607922
