You can reference by id
So you'd do something like:
<input type="text" id="Textbox">
<script>
	var x = document.getElementById("Textbox").value;
</script>
I haven't used JS in a while, but I'm fairly confident that's how you reference those values.
<script>
</script>
You don't the need the curly braces though.
To add to what's been said, HTML elements pretty much all support JS events. Check out w3c for all of them, but look into onchanged or onkeydown for sure. You could use that to call a JS function that updates each variable. Or if you are worried about performance update when the text box loses focus.
One thing is that you should validate all input server side where ever possible, because JS runs client side its very easy to change it to do what you want with the code as a user, and anything more than a contact form needs proper validation
